Coolant leak?
2002 VOLKSWAGEN PASSAT
173,000 MILES • 2.8L • V6 • 2WD • AUTOMATIC
WOMACK100
So, coolant won't stay in my reservoir leaking coolant from in front of my car, so I detached the upper hose from the reservoir I believe that hose run through the engine and pour water down it and some after it's leaks out front in front of the car. need help.
Sep 23, 2023 at 4:17 PM
I attached a picture below of the hoses related to the engine cooling system. If you have a leak from the reservoir, the one hose runs to the upper radiator hose. It could be leaking at that point. See pic below.
Also, if you haven't already, I recommend pressure testing the cooling system. When the engine is cold, make sure the coolant is full, and then, using a pressure tester, pressurize the system. If there is a leak, you should be able to locate it when it is pressurized.
Here is a link showing how it's done:
https://www.2carpros.com/articles/radiator-pressure-test
I hope this helps. Let me know what you find or if you have other questions.
See pics below.
Sep 23, 2023 at 8:54 PM
