Coolant dripping onto exhaust pipe under firewall. any problem areas in this location or thoughts on this matter? thanks
Jul 14, 2017 at 10:40 AM
SATURNTECH9
CERTIFIED EXPERT
A heater hose or the heater core is there any coolant inside the car on the front floor board? The best thing to do is try to rent a coolant pressure tester at a auto parts store like auto zone and pressure test the system and look for leaks that way.
Jul 14, 2017 at 1:07 PM
MOELLG
MEMBER
Not heater hose or core appears to be coming from head gasket or freeze plug need to inspect with mirror.
Jul 15, 2017 at 11:27 AM
SATURNTECH9
CERTIFIED EXPERT
They rent inspection cameras at auto zone I would rent one to have a better look.
Jul 15, 2017 at 1:55 PM
MOELLG
MEMBER
Thanx for response car had overheated several times due to faulty fan module before it was brought to me i suspect engine is all alloy and may have a cracked head or gasket will do further inspection
