Coolant leak
2014 GMC ACADIA
50,000 MILES • 3.2L • 6 CYL • 4WD • AUTOMATIC
AATORRES69
Our car has started leaking fluids it on driveway, seems coolant and I can smell the sweet smell. It does not leak all the time, but the temperature is going up on gauge and fans are kicking in. Any idea? No lights on, takes a bit for engine gauge to go up fans do kick in and run of a bit after car is off. still under power-train warranty, but not sure what to do.
Dec 12, 2017 at 10:28 AM
SATURNTECH9
  • 30,869 POSTS
Here is a guide to find the coolant leak there are dozens of places the leak could be coming from:
https://www.2carpros.com/articles/car-is-leaking-coolant
Also, they rent coolant pressure testers at AutoZone to pressure test the cooling system to find leaks. That is the method I use.
Dec 12, 2017 at 10:56 AM
