I am getting coolant in the spark plug well of cylinder two.
Five hundred miles ago I flushed the radiator.
One thousand miles ago I changed the plugs and wires.
Also about one thousand miles ago I changed the tube seals because I was getting a little bit of moisture in cylinder two. Not sure if it was coolant. But it was giving it a misfire.
The head gasket was done less then ten thousand miles ago.
The coolant is only in cylinder two. It looks like it had been still leaking but the new wire plug kept the spark plug dry enough to not misfire. I do not know? Why do you think there is coolant in the spark plug well? Any and all possibilities would be helpful.
May 7, 2018 at 10:31 PM
