Recently I repaired a leaky radiator after some time which I have been running water because of that. Drove it until normal running temperature then shut off for the night with no noticeable leaks. Started car in morning and noticed it was really sluggish all of the sudden like it was misfiring in a cylinder. Checked oil and noticed it was milky. (No oil in coolant). Had a rusted shut thermostat also that I removed. Drained oil which came out pure water (about full capacity for car) then the milky oil drained out afterward. then added coolant (water for testing). I left the oil pan plug screw out for this and when I filled radiator the water/coolant immediately came out of the oil pan drain. Also possible rust issues not sure. I’ve been running water for about 1 year with very light driving (under 3,000 miles).I will gladly pay any certified mechanic that knows why this is happening.
Nov 5, 2019 at 8:02 AM
