Coolant in oil, pop heard there was no coolant?
2008 FORD EDGE
236,000 MILES • 3.5L • V6
CRYSTALGRL
My car ran hot for the first time out of the blue with no one whatsoever. I pulled over pop heard there was no coolant in my reservoir and my oil had the milky mixed oil look. My question is, can I drain the oil and filter change out replace my water pump and timing chain without replacing the whole engine? Is it even worth doing or should I just get a new vehicle?
Mar 19, 2023 at 10:59 AM
It sounds like the head gasket let go but the engine is going to need to be disassembled. This guide can help you understand the problem better:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
You need to decide if the car is worth fixing by its condition and keep in mind that car payments will not stop for 5 to 6 years. I would get some estimates and weigh your options. Please let us know what's happens or if you need help with anything else.
Mar 19, 2023 at 5:47 PM
