It was four degrees outside I started the SUV drove three miles to the store it started to get hot but never reached the red. Overheated in the drive it shut off an would not start. next it started ran okay until I shut it off it, then it would not start again. drained the oil it was gunky. is it cracked block or head gaskets? I can run the water through the radiator and water will come out the oil drain plug.
Feb 3, 2018 at 3:16 AM
