Coolant in oil?
2005 FORD F-150
160,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
DBDISTURBD
Pouring coolant into heater core entrance goes directly into oil pan while engine is off.
Feb 20, 2023 at 7:19 PM
My first suspect is the oil cooler/oil adapter. (See pic 1 below) This is where the engine oil filter is installed. Note that the degas bottle and lower radiator hose connect to it. Coolant runs through it to help cool the engine oil. It sounds like it has failed internally and is allowing coolant to go into the engine.
If you follow the directions in pic 2, they explain how it is removed. This is where I would start to see if there is damage to the adapter or if there is a failed gasket.
See pics below.
Feb 20, 2023 at 8:18 PM
DBDISTURBD
I poured coolant in heater core entrance port beside water pump and it goes straight into oil pan.
Feb 20, 2023 at 8:45 PM
Take a look at the pics I attached below. Is that where you are adding coolant? If it is, that attaches to the coolant crossover assembly. There are two gaskets that may have failed.
If you look at pic 3, I highlighted the gaskets of concern.
Let me know if I have the correct location.
joe
Feb 21, 2023 at 8:18 PM
DBDISTURBD
Yes, I poured coolant in the crossover assembly on the heater core side (passenger side) and it went directly into oil pan with the engine off.
Feb 22, 2023 at 7:30 PM
Chances are one of the gaskets failed. I suggest removing the cross-over and inspecting the gaskets. Also, make sure nothing is cracked.
Let me know what you find.
Feb 23, 2023 at 6:32 PM
