I am not sure I understand the progression of events. The hose came off and all the coolant drained out of the engine and then the engine got hot and shut off? Now you found coolant in the oil?
If this is the case, I suspect the engine did get to hot and warped the head. Which means we need to drain the oil and refill it with oil and refill the coolant. Then test the head gasket. Here is a guide on how to do that:
Here is a guide that covers this issue in case you or others that view this post need it:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Let's go through this and go from there. Thanks
Oct 29, 2020 at 4:47 PM
