Using tape will not work to repair a broken or torn hose. The system is pressurized when the engine heats up, and tape is not strong enough. You should really just replace the hose. It will be cheaper in the long run because otherwise, you will be adding coolant all the time.
Here is a link that shows how to replace one:
https://www.2carpros.com/articles/replace-radiator-hoses
Nov 24, 2018 at 6:02 PM
