My heater will blow hot air, then once the engine warms, will start to blow cold. As soon as this happens, the coolant fluid will start to gush out of the reservoir. Loosing enough that the temp will rise hot.
I've replaced the thermostat twice. New water pump, new radiator, new heat control valve, new heat door actuator. I'm stumped. Could it be air in the coolant system? If so, how do I burp it?
Jan 12, 2016 at 1:45 PM
