I drained the old coolant and in process of refilling to clean the system; put distilled water in reservoir and thru radiator cap (which is right where thermostat is). I put in one gallon, the water is at top of both areas. specs say it holds about twelve quarts. Is there something I should be doing to get the water levels to lower so I can fill it completely?
Sep 21, 2017 at 11:58 AM
