Coolant flush
2013 JAGUAR XF
78,000 MILES • 3.0L • TURBO • 4WD • AUTOMATIC
PAYASA
How to drain and refill and is there a bleeder for the air?
Nov 19, 2017 at 10:16 AM
JIS001
  • 3,412 POSTS
Remove the coolant bottle cap off. There should be a plastic screw plug at the bottom of the radiator. Loosen just enough to where you see it draining. The sides of the block you should have plugs also you can unscrew to drain.
Here is the fill procedure and posting an image of what appears to be the bleeder screw:
CAUTION: Be prepared to collect escaping coolant.
1
Fill the cooling system, keeping coolant to the upper level mark of the expansion tank until a steady stream of coolant is seen running from the coolant hose bleed point.
2
Continue to fill the coolant until the maximum level is reached.
3
Set the heater controls to maximum.
4
Start engine and increase speed to 2000rpm for 2 minutes.
Continue to top-up with coolant with engine idling until hot air is emitted from face vents.
When hot air is emitted from the vents, switch the heater off.
5
If no hot air is emitted, repeat step 7.
CAUTION: Correct installation of the Coolant expansion tank cap can be obtained by tightening the cap until an audible click is heard.
CAUTION: Switch off the engine and allow the coolant temperature to go cold.
6
Switch the engine off and allow to cool.
7
Visually check the engine and cooling system for signs of coolant leakage.
WARNING: When releasing the cooling system pressure, cover the coolant expansion tank cap with a thick cloth.
CAUTION: Since injury such as scalding could be caused by escaping steam or coolant, make sure the vehicle cooling system is cool prior to carrying out this procedure
CAUTION: Make sure the coolant level remains above the "COLD FILL RANGE" lower level mark.
NOTE:
When the cooling system is warm, the coolant will be approximately 10mm above the upper level mark on the expansion tank with the cap removed.
8
Check and top-up the coolant system as required when cool.
Nov 19, 2017 at 3:11 PM
