Where is the coolant fan temperature switch located?
2008 HONDA FIT
208,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
I've been told that I need to replace my coolant temperature switch, so I bought one. My problem is that I can't find its location. parts store couldn't tell anything.
My problem is that's leaking water, I think it's coming from the radiator plug. engine coolant fan not working. acc fan works only. I bought a fan for it. but if the switch isn't good,, it still wont come on.
Feb 20, 2022 at 1:15 PM
WENDY W
  • 86 POSTS
Hello!
I've attached the component locations for the engine coolant temperature sensors and a schematic for the cooling fans and ECT sensors (below).
Additionally, you may find these tutorials helpful:
https://www.2carpros.com/articles/car-is-leaking-coolant
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
This video describes what is involved in performing a cooling system pressure test to check for coolant leaks:
https://youtu.be/W8kra65m15c
Please let us know what you find and if there's anything else we can help with.
Thanks, Wendy W
Feb 21, 2022 at 7:42 AM
