The coolant appears to be mixed with the oil in the oil fill cap. But not present at all on the dip stick. No oil in coolant reservoir or radiator.
The vehicle was running rough before replacing it with a brand new radiator, thermostat and transmission fluid. (I actually did not look to see if the oil was contaminated previous to radiator change.)
Vehicle is running great though no white smoke, no overheating, runs smooth.
Should I buy the kit to check for head gasket damage? I also have blue devil head gasket repair fluid but hesitant to use encase it is not the problem.
Mar 19, 2018 at 7:17 AM
