Coolant and oil mixture
2008 OPEL CORSA
320,000 MILES • 1.7L • 4 CYL • TURBO
WILLEM JOHANNES
We have overhauled the engine.Block and cylinder head skimmed and pressure test. New gaskets on, but the oil and water mix immediately after starting the engine.The oil show creamy color. What could be the problem?
Oct 17, 2019 at 11:45 PM
Unfortunately we don't have a manual on your vehicle and engine so I cannot look up how it is equipped but do you have an oil cooler?
Normally this is the other most likely cause.
Here is a guide that will take you through the most common causes:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Let us know if you have questions.
Oct 18, 2019 at 5:00 PM
