coolant and oil gauge not working
1990 FORD F-150
80,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
BIGKEITH150
oil and coolant temp sender units have been changed. instrument cluster has been changed with known good one. cool ant and oil gauges still read dead. all low. no sweep.
Oct 13, 2015 at 1:56 PM
HMAC300
  • 48,601 POSTS
pics show how to test gauges you need resistors and a ohm meter. you can get resistors if you have a radio shack around. see if senders are getting a low voltage signal or a flashing light with a test light. if not it's a wiring issue. I screwed u p on this and sent info for testing coolant instead of oil pressure but they test the same anyhow........pics show color of wires to test
Oct 13, 2015 at 3:39 PM
CJ MEDEVAC
  • 11,004 POSTS
CHECK FUSE # 18
ALSO CHECK TO SEE IF THERE IS VOLTAGE TO IT
THE MEDIC
Oct 13, 2015 at 4:15 PM
