Contuned backfire issue
1977 FORD F-150
2,000 MILES • 5.8L • V8 • 4WD • MANUAL
CHRISS CRAWFORD
  • 6 POSTS
This has gotten to point can't drive truck. things done and tested: carburetor o/h, Edlebrook 1405. played with jets and rods. isolated ignition circuits. start circuits, changed distributor, pick up. replaced box. compression test ,150 across all cylinders. installed ballast resistor. voltage seems a bit high out of ballast and increases as rpm goes up, even with regulator disconnected. I've been a master tech over twenty years, I am 64 Monday and had a wrench in my hand since I was about 13. I feel like I'm missing something just can't put my finger on it Thank you for any and all help.
Jun 6, 2019 at 11:42 AM
KENW1
  • 213 POSTS
Welcome to 2CarPros. Is it backfiring out of the exhaust or carburetor? What ignition set up are you using?
Jun 6, 2019 at 8:40 PM
CHRISS CRAWFORD
  • 6 POSTS
mostly exhaust, sometimes intake. duraspark 2.
Jun 7, 2019 at 6:04 AM
CHRISS CRAWFORD
  • 6 POSTS
Adjusted valves yesterday, I think I still have one intake too tight, because it's mostly backfiring intake. Have fast idle set to 1,800, roughly. set distributor to number 1 TDC. Balancer is indexed correctly , will sort of start just around 500 rpm then shuts off, or backfires and shuts off.
Jun 7, 2019 at 6:10 AM
KENW1
  • 213 POSTS
Thanks for all the additional information. Have both 351 firing orders been tried?
Jun 7, 2019 at 10:10 AM
WRENCHTECH
  • 20,761 POSTS
Just some general thoughts.
Backfiring indicates the fuel is combusting at the wrong time so we have to be looking at some sort of ignition issue. You said you changed a distributor. Did that include the cap and rotor? Those would be my priority suspects along with cross-firing wires or a bad coil. The primary side sounds all brand new so I would just confirm the power supply isn't being interrupted.
Jun 7, 2019 at 10:30 AM
HMAC300
  • 113 POSTS
Take valve covers off and see if all are working. it may be a worn out cam or lifter bad or both. also check for a bent push-rod.
Jun 7, 2019 at 12:05 PM
DANNY L
  • 5,648 POSTS
Sounds like a timing issue.
Jun 7, 2019 at 2:02 PM
WRENCHTECH
  • 20,761 POSTS
In order for this to be a valve problem, it would have to be a continuous miss, not random. It also would have failed the compression test and likely made noise if valves were the issue. With an ignition timing problem, the backfire would be under acceleration only. If it is a completely random popping, that would have to be ignition. You never really described the type of backfire you are experiencing.
Jun 7, 2019 at 2:07 PM
CHRISS CRAWFORD
  • 6 POSTS
Thanks for all the input. As stated just did valve adjust, and got worse, did the adjust per firing order,(covers off, plugs out) engine only has 2,100 miles on it. block casting below. All started about seven months ago, with a major backfire from exhaust. flash of light so bright it reflected off a white wall as i pulled up to a stop sign. Just left work 05:00. Denver. Truck had been flawless for eighteen months. seems like I've made matters worse with every attempt. I do not know why it happened, no amount of checking has lead to cause of first backfire, nor any repair has changed anything for the better, only gotten worse. Now I sound like I'm whining
Jun 8, 2019 at 8:50 PM
STEVE W.
  • 15,113 POSTS
You changed dizzy and wires, what about plugs?
Jun 12, 2019 at 6:30 AM
CHRISS CRAWFORD
  • 6 POSTS
yes new plugs, also just installed new BWD OEM coil and connector
Two kinds of backfire out of exhaust. #1 is hugh single bang like a gun shot.
The other is more like a rumble, very low rpm, will not come up. and dies, restart same rumble, low idle, shuts off, restart third time dies right away, hugh backfire. All out exhaust.
Static timing to number one TDC vac advance plugged, sometime starts and runs up to 2500, set total timing to 34 degrees , let it idle and the backfire starts.
When i was still able to drive the truck the huge gunshot backfire was on deceleration.
Jun 12, 2019 at 12:27 PM
STEVE W.
  • 15,113 POSTS
Okay, to be sure I have it straight it was rebuilt and running fine then the big backfire and it hasn't run without backfiring since. You rebuilt the carburetor, changed out the ignition system and still no go. I'm thinking the backfire may have been excess fuel getting into the exhaust system and igniting. Maybe drop the exhaust and see if things improve. What has been changed from stock on this engine?
Jun 12, 2019 at 12:54 PM
