Controls on my steering wheel are no longer working
2015 CHEVROLET SPARK
743,224 MILES • 4 CYL • 2WD • AUTOMATIC
LYONS4EVER5
Also the temperature reading on the radio has disappeared. I checked fuses. I don't know what else to do.
Jan 4, 2020 at 4:10 PM
JIS001
  • 3,412 POSTS
There is a bulletin to check for an unplugged ambient temperature sensor or open in the circuit. If all is good the ambient sensor is faulty.
#PIC6215A: AC Inoperative and/or Ambient Temperature Display Missing from the Radio - (Sep 14, 2018)
Subject: AC Inoperative and/or Ambient Temperature Display Missing from the Radio
Correction
Dealer to isolate and repair open circuit to the ambient temperature sensor.
Service Procedure:
Use GDS2 to check ambient temperature in the IPC data.
If it reads -40 there is an open to the ambient temperature sensor.
This leads to the radio not displaying a temperature and AC is also inoperative
Check for unplugged connectors or damaged harness to the ambient temperature sensor.
As for the steering wheel controls I would suspect a faulty clock spring.
Jan 4, 2020 at 11:48 PM
