Control arms low
2014 TOYOTA HIGHLANDER
135,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
MONCHO6685
  • 118 POSTS
My brother needs to change lower control arms in his vehicle. How difficult it's that work? From 1 to 10?
I know original parts supposed to be the best replacement parts, but from the photos that i send here which one you select is the better one? With all of your heart.
May 31, 2019 at 4:38 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Beck Arnley is a good choice (photo number 4). Here is a tutorial showing what is involved.I would rate it as a 7 in difficulty:
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
Hope this helps and thanks for using 2CarPros.
Danny-
May 31, 2019 at 6:43 PM
STEVE W.
  • 15,113 POSTS
That style arm isn't bad if you are in an area where they don't rust much. The hardest part is getting the ball joint out of the knuckle. The rest is just unbolt one and bolt the new one on. You will want an alignment after it's done but it should be real close unless the parts are made wrong as the arms are not really adjustable. The last time I did that style arm on a different make it was less than a tenth of a degree off.
May 31, 2019 at 9:16 PM
MONCHO6685
  • 118 POSTS
Thank you so much Danny l and Steve W. For your support. I learn a lot with all of you it makes me a better technician and my "clients" are satisfied with my work. Thanks a lot for the support. I really appreciate this help. God bless you all.
Att. Juan Marin.
Have a nice weekend.
Jun 1, 2019 at 4:21 AM
DANNY L
  • 5,648 POSTS
You're welcome! Thanks again for using 2CarPros.. Feel free to ask us again.
Danny-
Jun 1, 2019 at 5:06 AM
