I am replacing the control arms on my i30 and just want to know when to tighten the bush link pin nut to the control arm...with the tires on the ground or with the control arm with no weight on it. I have them completely installed one side so far and I tightened it with the control arm just hanging freely but it seems like the car is higher then it was. So I don't know if I should loosen the nut with the tires on the ground with full weight on it, letting it settle then re tighten the nut in that position or just leave it as I have it now...any help would be appreciated...Dave Image page SU_8
Apr 16, 2013 at 8:49 AM
