One item I don't see mentioned, check the vehicles fuel pressure regulator and the actual fuel pressure. The regulators can fail internally and most are connected to the vacuum system which can give you an uncontrolled fuel source that the engines systems wont try to compensate for. Another issue could be high fuel pressure from a bad regulator or pump. That can cause the injector to spray in a larger amount of fuel that the system thinks it's getting. Depending on how advanced the computer is it may or may not try to compensate for it depending on how much extra it sends. To check that closer you could use a scan tool to look at the actual fuel trims as the engine is running. Ideally you would want to see them at very close to zero on both long and short term trims. If however you see the long term or both showing a negative number, there is extra fuel getting in somewhere.
Also check what the coolant temperature sensor is showing, and compare that with other temperature sensors. If the coolant is fully warmed up but the ECM sees a very low temperature it could be running in a heavy enrichment mapping thinking it is in a very cold area, that can cause a lot of fuel use, but the computer wouldn't see anything was wrong.
Have there been any changes in your driving routine like more air conditioning usage or more stop and go traffic than before? Even something like changing fuel stations can cause fuel consumption differences. I don't know if your country adds ethanol to the fuel or not, I think they do. If they changed the percentage or if you simply got a bad tankful it could cause problems.
Dec 19, 2019 at 1:24 PM
