Connecting rod bearings replacement
2000 DODGE DAKOTA
187,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
ABSTRUSE_SOUL
I'm replacing my connecting rod bearings and on one rod there is still up and down play, all of the other rods are fine. What could cause this issue and what is the next step i should take?
Feb 9, 2020 at 3:52 PM
94 TRANSAM
  • 680 POSTS
First I have to ask, did you plastigage the new bearings when you put them in?
Replacing bearings isn't just an easy swap like a starter. You must plastigage them to make sure you have proper oil clearance.
There are several ways to deal with clearance issues.
Too tight with a standard bearing means try a different set of bearings or have the crank milled.
Too loose means you need an over sized bearing and then if the clearances are too tight you have to mill the crank.
See diagram below.
Rich
Feb 9, 2020 at 7:44 PM
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Feb 10, 2020 at 3:47 PM
