Connecting a metal line from an exhaust hole (next to the heat tube to the choke) and a line with a small check valve attached to it.
I installed a new heat tube from the exhaust to the choke assembly. Next to the heat tube there is another hole and another tube going to the rear of the engine. What do I connect to this tube?
I also have a vacuum type line with a check valve attached to it (looks like it goes into the fire wall/heater area) where do I connect this line?
Is there a source that I can find pictures of this information on line?
Thanks for your help. Gus
Sep 3, 2013 at 12:53 AM
