condenser fan relay location needed
2007 DODGE RAM
88,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
Where is the condenser fan relay location?
May 4, 2021 at 12:38 PM
Good afternoon,
There is no relay for the fan motor. It is controlled by the integrated power module under the hood. The fan is activated by the module when it sees Freon pressure on the high side above 150 pounds.
The module is a common failure. I attached a wiring diagram for you. I also attached the part from Rock Auto.
May 4, 2021 at 5:40 PM
Thank you for the Information you sent me. To get that module replaced would you know a ballpark figure how much it will cost?
May 5, 2021 at 9:33 AM
From the parts, I found new, $1,200.00 to $1,400.00.
May 6, 2021 at 3:17 PM
