Computer update after replacing MAP sensor
2011 VOLKSWAGEN JETTA
130,000 MILES • 2WD • AUTOMATIC
PHLYINLO
Does the car's computer need to be updated after replacing the MAP sensor and if so how much should be charged for this?
Jan 7, 2020 at 2:05 PM
CARADIODOC
  • 34,306 POSTS
Unless there's something unusual I'm not aware of, this type of sensor is just plugged in, and off you go into the sunset. No two sensors are ever exactly alike, so the Engine Computer has strategies to compare them to each other and to engine operating characteristics, to learn the "personality" of a replaced sensor. That takes place very quickly as soon as you start driving.
There are some sensors on newer models that do need to be programmed but for most cars, that would have to be done any time the battery was disconnected or run dead. VW, BMW, and Audi do have a lot of tricks designed-in that cause computers to lock up when the battery is disconnected. That can require a very expensive tow to the dealership, but not when you're just replacing a sensor. Just be careful to not disconnect the battery.
As for cost, the only thing I've heard multiple times is if the battery is disconnected on a BMW, the total bill was over $950.00 to unlock multiple computers. Some people say that is true for some GM models too, but I've never heard anyone say that happened to their car.
Jan 7, 2020 at 2:22 PM
