You wont need to rewire anything at all.
All you need is a ignition on a signal from the fuse box for your MSD system. once you have that, there is no need for the computer system.
Nice conversion. I did a couple of these years ago and it worked out great. I used the holley pro jection system.
Take the harness for the computer system and just tie wrap it away from the engine. Wiring such as alternator, temp sender unit you need out of the harness but that is easy.
Nov 6, 2018 at 3:03 AM
