Computer and code PO0016
2005 DODGE STRATUS
119,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MARK CUMMINGS
  • 6 POSTS
The scan tool that I have only tells me , that it is a PO0016.
Jun 10, 2018 at 1:36 AM
Good morning.
This code is for crankshaft position sensor out of line with the camshaft sensor. This could mean a timing issue between the crank and the cam.
You may a streched or worn out timing belt.
P0016
Item Description
Symptom/DTC P0016
Descriptor
Crankshaft/Camshaft Timing Misalignment
Probable Causes
Camshaft Position (CMP) Sensor
Camshaft Position (CMP) Sensor Wire Harness
Crankshaft Position (CKP) Sensor
Crankshaft Position (CKP) Sensor Wire Harness
Intermittent Camshaft Position (CMP) Sensor Signal
Intermittent Condition
Intermittent Crankshaft Position (CKP) Sensor Signal
Tone Wheel/Pulse Ring
Jun 10, 2018 at 6:47 AM
MARK CUMMINGS
  • 6 POSTS
I recently swapped motors in my car. Replaced it with a 2006.They both are 2.4. My problem is that I am getting a crankshaft , camshaft code. I replaced the crankshaft sensor and cam sensor and still got the code. I took it to a shop and told me the timing was off 14.1 degrees. So I got the motor top dead center and both cams lined up perfect. The car runs great, except when I stomp on it. It hesitates at about 2,500 rpm's, and if I let the gas off a little it runs fine. Do you think that I have to get the computer flashed to match the 2006 motor? Pulling my hair out, must pass emissions.Thank you, Mark from Phoenix.
Jun 10, 2018 at 11:44 AM (Merged)
CARADIODOC
  • 34,306 POSTS
You need to list the exact fault code numbers. The engine runs on the crankshaft position sensor up to 2,500 rpm, then it switches to the camshaft position sensor. If you have a scanner, you should be able to look at how those sensors are listed under "Inputs/Outputs". I have a Chrysler DRB3 for all of my vehicles. It lists those sensors with a "No" or "Present" to show whether their signals are showing up at the computer.
