Hi, Fan velocity switch is defective. AC only turns ON if I hold fan switch with fingers. I deduce that with vibrations along the way, on a constant ON-OFF cycles, magnetic coil that engages AC compressor died. I know I need a new fan switch, and a new magnetic coil to compressor.
My questions are:
-How do reach fan switch? Can´t find on manuals how to remove center fascia...
Do I have to do the same steps as remove dashboard?
-Is it easy to pull out magnetic coil by hand?
Manual says it may be needed a "puller". But there's no space to use a puller without dismantling AC compressor.
So by hand and with a puller will be the difference between collecting gas, install new dryer, removing AC compressor, recharge gas, etc...
Will be the difference between replacing magnetic coil at home by me, or send the Starex to an auto shop.
Can you help me with some tips? Thanks in advance!
My questions are:
Oct 19, 2019 at 5:34 AM
