Three of my cylinders tested at 150 lbs comp but one of them tested at 90 lbs. just wondering why such a big difference?
Mar 21, 2018 at 3:33 PM
KHLOW2008
CERTIFIED EXPERT
It could be due to dry or worn piston rings, leaking valves or head gasket. Give it a wet test and if the compression increases, that would be a fault of the piston rings.
