Just did compression check on the Ram van 1500 listed above. All the cylinders have around 120 to 130PSI. But the number four cylinder only has about 30/32 PSI and number 6 cylinder is at 105/110. I believe I'm right on firing order from inside the cab looking forward I was told passenger side back to front 1,3,5 and driver's side from inside cab looking forward 2,4,6. Thanks, I hope it's just stuck. Sat for 5 years. Came out of California. Runs good just rough idle once you get it up a little speed it runs smoothly. Thank you much.
Keven Watts, Indianapolis
Jun 16, 2022 at 6:54 AM
