Complete electrical loss
2003 MERCURY SABLE
102,300 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
COUNTRYCLUBLDY
But if pop hood will start. Sometimes it shuts down when driving.
Oct 12, 2019 at 6:28 PM
CARADIODOC
  • 34,306 POSTS
Follow the smaller battery positive wire to the under-hood fuse box. Clean and tighten that connection. That is a common cause of this problem on almost all car brands.
Also follow the smaller negative battery wire to where it bolts to the body sheet metal. Be sure that connection is tight and not rusted. The strands of that wire can also corrode back under the insulation where it can't be seen.
This complaint used to be caused by loose or dirty battery cable connections, so check those too. Here's a link to a related article:
Oct 12, 2019 at 7:01 PM
COUNTRYCLUBLDY
Will check it out, thanks.
Oct 18, 2019 at 3:44 PM
Oct 18, 2019 at 3:45 PM
