Compatible transmission
2000 CHEVROLET BLAZER
185,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
TATVAL69
Transmission has a grinding noise and will not shift past second gear into third gear. What other transmissions are interchangeable?
Aug 3, 2018 at 5:16 AM
Good morning.
What transmission do you currently have?
Aug 3, 2018 at 6:47 AM
There is only one listed for your truck. The chart is attached.
You could replace it with other GM transmissions but wiring will have to be replaced to make it work as well as flashing the PCM to see it.
Aug 3, 2018 at 6:51 AM
