If the thermostat is leaking, chances are it just needs resealed. As far as other vehicles compatibility with your vehicle, you would have to actually look at them to confirm they are the same. It seems like everyone of them are different in some way.
Now, can you tell me where it is leaking from? Is it the hose, where the housing mounts, or is the housing cracked? Also, when you installed the new thermostat, was the housing and where it mounted clean and dry? Are you sure the thermostat was properly positioned prior to installing the housing? Was the gasket/o-ring in good condition?
Here is a link that shows how in general one is replaced. Make sure you followed these directions.
Here are the directions specific to your vehicle for replacement. Read through them to confirm you did everything it shows. The attached pictures correlate with these directions.
______________________________
PROCEDURES
Removal
1. Drain the cooling system.
2. Disconnect the thermostat hoses.
3. Remove the thermostat cover.
1 Remove the three bolts.
2 Remove the cover.
4. Remove the thermostat.
Installation
1. To install, reverse the removal procedure.
2. Refill the cooling system.
Let me know. If you plan to get one from another vehicle, it will have to be the same model year, engine, and then you would have to confirm it is the same.
Let me know if this helps.
Dec 21, 2018 at 5:41 PM
