Combustion misfire
2015 PEUGEOT 208
18,400 MILES • 1.2L • 3 CYL • 2WD • MANUAL
TERRY MC FEELY
Car jump's, loses power, warning lights come on and idles badly. changed plugs 1 coil pack on cylinder 1 coolant on inside of coil pack.
Jul 3, 2020 at 4:15 AM
Have you performed a compression test? If not, we need to do that. Here is a guide that will help on how to do it:
Sounds like you may have a head gasket issue which will show up on a compression check. However, here is how to test the head gasket as well:
We don't have a manual on your vehicle because it is not offered here in the USA but we can help with more general information because it sounds like a pretty straight forward compression issue as you mentioned. So that means we need to perform the test and see what we have. Thanks
Jul 3, 2020 at 9:39 AM
TERRY MC FEELY
Thanks. will get my mechanic to try this.
Jul 3, 2020 at 10:24 AM
Sounds great. Keep us posted with what you find. Thanks
Jul 4, 2020 at 6:59 PM
