We took my wife's daily driver into our mechanic because of a coolant overheating issue that just surfaced. They confirmed that we either have a bad head gasket or a cracked/warped head.
Prior to taking it in for inspection I replaced the vehicle's thermostat, water pump, and both radiator hoses attempting to remedy the situation.
I have ordered a set of new head gaskets (along with many other gaskets: exhaust, intake, etc.) along with new head bolts.
I have also ordered two can of Bar's Leak Head Gasket Repair.
The van has 183,000 miles on it. We would like to repair it and get a few more years of service before replacing it.
My questions are:
Should I attempt to fix the issue first by using the Bars Leak-branded fix in a bottle?,
and if so, should I bypass the heater core(s) and remove the thermostat while the bottle of goo does its thing?
Removing the thermostat and bypassing the heater core are not recommended by Bars though their wording states that bypassing a "clean" heater core is not necessary. Obviously our heater core is not in new condition so by definition I cannot claim that it is "clean."
Any advice most appreciated!
Thank you.
My questions are:
Thank you.
Dec 11, 2019 at 8:30 AM
