Cold start it runs perfectly after it warms up to normal operating temperature it shuts off?
2002 CHEVROLET MONTE CARLO
200,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
JACK73
Hello, I'm Jack. Will not start back up until temperature gets cooler. After shutdown I sprayed starting fluid into the intake, and it didn't even try to start up.
Jul 15, 2024 at 4:28 PM
I believe the crankshaft position sensor is bad. When they begin to fail, they get adversely affected by heat which shuts spark off to the plugs (starting fluid didn't work).
Take a look through this link and let me know if it mirrors what you are experiencing:
Let me know your thoughts. I feel somewhat confident this is the problem.
Jul 15, 2024 at 6:34 PM
JACK73
Hey Joe. I really appreciate the quick response and your knowledge. I was leaning more towards the sensor more so than the Ignition Control Module. Only thing that is making me sort of second guess myself is that I checked for spark out of the plug wires and as the motor was turning over, I could see spark, but it did look like a fairly weak spark as opposed to the spark I get when the car is Running. Thanks again Joe. I appreciate you.
Jul 15, 2024 at 7:03 PM
Double check for spark. If it is present, it should be a blue snapping spark. If it appears white or orange, that would indicate it is weak.
On the other hand, even a weak spark should have done something when using starting fluid. My gut feeling is the crankshaft position sensor is the issue, but I have been wrong before. LOL
Here is something we can do. If the vehicle has a tachometer, see if it moves a bit when cranking the engine in a no start condition. If there is no movement, the sensor is the likely issue. Also, if you have a live data scan tool, check for an RPM signal when it won't start. If there isn't one, replace the sensor.
Let me know your thoughts or if I can help in any way.
Jul 16, 2024 at 7:47 PM
