Welcome back:
You know, I question a couple things, but I have no idea what they have already done. Has anyone checked fuel pressure? Also, has the vehicle been checked for simple engine vacuum leaks?
Take a look through the following. When you have a misfire related to one bank (which is questionable when you have a p0300) here is a list of possible causes.
- Electric fault or loose contact in the control line to solenoid valve of camshaft adjustment
- Solenoid valve of camshaft adjustment electrically/mechanically faulty or clogged
- Hall sender rotor (sensor wheel) faulty/kinked
- Secondary air
- Intake camshaft adjustment too slow
- Intake camshaft timing incorrect
- Exhaust camshaft timing incorrect
- Fault in the valve lift control
- Oxygen sensor faulty (also: loose contact in wiring harness)
- Exhaust system blocked/narrowed
- Foreign bodies in intake tract, this can lead to sporadic misfires on changing cylinders.
Are the codes you listed originally the only ones that were ever set? Also, and don't laugh, are you using premium fuel? Low octane (below 91) will cause driveability issues and misfires on this vehicle. It's just a thought.
Oct 8, 2019 at 6:14 PM
