No spark
1997 FORD
169,000 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
SHEILA STANCIL
My engine turns over but coil will not fire.
May 16, 2017 at 11:49 AM
The most common cause of no ignition spark is a faulty crankshaft position sensor. I'm not certain what vehicle you have, so I can't provide the specifics for you. However, take a look through these links. They explain how a crankshaft position sensor works and common symptoms.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
If you determine the sensor is bad, here is a link that explains in general how one is replaced:
I attached a pic below showing the location of the sensor on a Ford Taurus 3.0L as a reference for you.
I hope this helps. Let me know if you have other questions.
Jul 19, 2021 at 9:46 PM
