None of the coils you have is giving you any spark at all. There is a current limiting resistor in the feed circuit on the yellow wire. But did the vehicle run before you started the tune up?
There is also a capacitor on the feed circuit that comes off the same power connection to the coil and it goes to ground. It's to suppress any transient voltage that might interfere with other sensors on the vehicle. It should also be on the same yellow wire and just bolted near the coil to the engine block. If this diagram is correct, but if the vehicle ran before the tune up, then there's something else going on. Possibly a bad control module, but if you get a test light you can check for coil control, and it will limit the possibilities here.
This is the capacitor, but I really, we need to know if you are getting any spark at all, if you are then we know the coil is being controlled at least. These older ignition modules went bad all the time, especially the aftermarket parts they are making now. We see a lot of bad brand-new parts. So, the module is suspect too. If it's not able to completely ground the coil or for long enough,
I would stick with the coil that has at least 10-volts for now but see if the module is controlling it. I think these in series resistors are a very low value,
Does the Tachometer jump while cranking if you have one?
Okay, I was just looking through some old posts, and it looks like there won't be a full 12-volts at the coil on these. I'm going to ask if I can post this info for you.
Sep 26, 2023 at 1:02 PM
