Number one and four coil failure
2009 HYUNDAI ELANTRA
650 MILES • 1.6L • 4 CYL • 2WD • MANUAL
ROBINAFOR
  • 34 POSTS
number 1 and 4 of coil is always having problem. I have changed coil more than four times by different mechanics. I observed a breakage on plug wire head and fixed it but it did not solve the problem. I observed that spark plugs from number 1 and 4 that are always failing are usually slightly soak with oil each I removed them for inspection. I need help please. I bought the car as a used car and the only major problem has been coil failure and its always from the number one and number four coil.
Jan 20, 2019 at 2:03 AM
Good morning,
It sounds like the oil is leaking from the valve cover seals and getting to the wire ends. that will force the coil to max output and will fail.
https://www.2carpros.com/articles/replace-valve-cover-gasket
Did none of the techs tell you about the oil leak?
Jan 20, 2019 at 8:43 AM
ROBINAFOR
  • 34 POSTS
None of the techs told me about this but I observed on my own that the spark plugs for number one and number four are always slightly wet with oil each time I remove them for inspection. the other two and three are only having slight dried carbon (I hope you get my point as I may not be using the right terms). I find your response useful, but what should I do to rectify this problem once and for all? again, do you thing the problem could equally be connected to a faulty plug wire? thanks for your prompt response. kind regards.
Jan 20, 2019 at 11:47 PM
Yes, the plug wires are failing due to the oil in the well.
Replace the valve cover gasket with the seals.
Jan 20, 2019 at 11:56 PM
ROBINAFOR
  • 34 POSTS
Do I need to change the coil, plug wires and spark plugs after replacing the valve cover gasket and the seal? and to add, I once personally observed current escaping from coil 1 to coil 4. the current from coil 1 was strong while the one from coil 4 was weak. I observed closely and noticed that there was a breakage on plug wire head 1 from where the current was escaping. I sealed it afterwards, anyway. I'm adding this extra information with the hope of helping you help me find a solution to the problem. thanks again for your prompt response.
Jan 21, 2019 at 3:06 AM
After the gasket is done, yes, I would replace the parts again as they are contaminated by the oil.
You are welcome.
Always glad to help.
Jan 21, 2019 at 3:09 AM
ROBINAFOR
  • 34 POSTS
Sir, should I exclusively key in to the valve cover gasket and seal replacement as a solution to the problem or is there another possible cause to the problem that I need to know about? Appreciate your great concern.
Jan 21, 2019 at 4:17 AM
I am here and not there. I base my advice on your input.
From what you told me, I would replace the valve cover gasket and seals and also the coil and wires.
Jan 21, 2019 at 4:20 AM
ROBINAFOR
  • 34 POSTS
You've been quite helpful, Roy. I hope to let you know how I go with it. Kind regards.
Jan 21, 2019 at 5:00 AM
You are welcome.
Jan 21, 2019 at 5:04 AM
ROBINAFOR
  • 34 POSTS
Hello Roy, I thought I should ask about something extra I just remembered. As I remember, the first two coil failure I experienced with the car were accompanied by fuel pump failure. Do you think this were simply coincidence or the coil failure triggered the fuel pump malfunction? Thanks.
Jan 25, 2019 at 9:14 AM
That was a coincidence. A failing coil will not cause a fuel pump failure.
Jan 25, 2019 at 9:17 AM
ROBINAFOR
  • 34 POSTS
Hello Roy,
it has been a while. I've fixed the coil, changed the plug wire and spark plugs . The car is working fine now. will be observing the car closely to check for a re-occurrence (I do hope it doesn't occur again, though). Thanks and I'll always keep you updated.
Kind regards.
Feb 14, 2019 at 9:57 AM
ROBINAFOR
  • 34 POSTS
Forgot to mention that I replaced the valve cover gasket like you advised.
Feb 14, 2019 at 9:58 AM
ROBINAFOR
  • 34 POSTS
Hello Roy. I thought I should let you know. After following your advice to fix the car I've not had a related reoccurrence. I'm still observing the car, however as using it for long without a reoccurrence will actually indicate a permanent solution to the problem. Once again, thanks. Kind regards.
May 1, 2019 at 11:18 AM
Your welcome
Always glad to help
May 1, 2019 at 1:03 PM
ROBINAFOR
  • 34 POSTS
Hello Roy,
Having used the car for this long without a recurrent issue, I've finally concluded that your solution to the problem was indeed a nib in the bud. I really appreciate this. However, a new problem has just surfaced and I hope you'll be of help.
The new problem is, car just stopped all of a sudden and wouldn't start but fans keep rolling. The first tech simply cleaned the spark plugs and replaced them then car started again but the same issue reoccurred after a while. Second tech changed the nozzle then car started but the same problem reoccurred. My observation is this, when the car stops, it restarts again much later even without any repair. I think the two techs are yet to get the real problem. I've checked to make sure the problem has nothing to do with the fueling system as the fuel pump is working fine. I need your help once again.
Jun 16, 2019 at 12:14 AM
ROBINAFOR
  • 34 POSTS
To add to the above, the car stopped last night and wouldn't start. I left the car and went home afoot. The next morning I went back to the car and tried it again and it started without delay. I'm just not confident enough to take it out with my family with this sort of issue. thanks.
Jun 16, 2019 at 12:17 AM
Hello again,
I would start by checking the actual fuel pressure when it will not start. Sounds like a fuel delivery issue.
Ry
Jun 16, 2019 at 4:08 AM
ROBINAFOR
  • 34 POSTS
Thanks again for the reply. If you don't mind, might I add some more info about the problem. About the fuel pressure, the mechanic actually confirmed that the pressure was okay but not with the fuel pressure gauge you talked about. He merely loosened a hose and inspected the fuel supply and told me the pressure was okay. This was before I sent you this mail.
Just to let you know, the car starts normally. This morning I warmed it and it was okay. it started well. But, it's like after it has run for a while, say some miles, it shuts down and wouldn't start until much later. this is what I observed. I am still going to consider the fuel pressure issue ( I'm yet to see my tech). But I felt I should let you know about this other issues with the car perhaps you may have something more to add. Just saying, do you think it could be a sensor related problem?
Thanks for the attention.
Jun 17, 2019 at 5:48 AM
That test was not accurate at all. You need a specific pressure and needs to be checked with a proper gauge.
Are there any codes?
He needs to do the correct diagnostic when it will not start.
Jun 17, 2019 at 6:51 AM
ROBINAFOR
  • 34 POSTS
Hey Roy.
I'm yet to check the fuel pressure like you advised because my tech is not available. He'll need to come over to my house to run the test. But just to let you know, still, I've taken the car out in the past three days but on very very short drive. The car didn't give any problem as mentioned before. However, I'm not confidence enough to take it on long drive, say to my work place, because I'm not sure of the car. Is it suppose to allow these drives even with the problem? And, just to know, supposing the fuel pressure is actually the problem then what would be the solution?
Thanks.
Jun 20, 2019 at 10:31 AM
If the fuel pressure is the issue, you will need a fuel pump.
Jun 20, 2019 at 12:02 PM
ROBINAFOR
  • 34 POSTS
Hello Roy,
I instructed my tech to replace the fuel pump like you suggested. He was still considering something else as the culprit but I insisted on the fuel pump so he went ahead to replace it and that actually solved the issue. I've used the car for a week straight and no recurrence of the problem. I'm so grateful Roy. Again, thanks a mil.
Jul 5, 2019 at 11:48 PM
ROBINAFOR
  • 34 POSTS
Hello Roy. I think I'm beginning to have issues with the fuel consumption. I think the car is consuming more fuel than it's necessary. I have also observed of late that the rev is usually high when I'm going on slow( say driving through many potholes). What could be the culprit here? Thanks.
Jul 12, 2019 at 7:12 AM
It could be the transmission shift points. Does the transmission shift at the correct speed?
You may want to service it first.
Jul 12, 2019 at 7:15 AM
ROBINAFOR
  • 34 POSTS
Thanks for the reply. But I might have been hastily in the post. I'm sorry for this. The deception into thinking the car was consuming too much fuel was because of the fuel gauge that stopped working. Actually, the car stopped while I was going to work. I thought it was fuel. After work I came with fuel but decided to try the car before putting the fuel. I was surprised to find out that the car started. It turned out that there was fuel in the car. Why did it stop? I asked myself. The way it stopped was like the last issue that's got to do with the fuel pump. I called my mechanic and told him he's got to change the fuel pump. He said that he would check the fuel filter for blockage. I expressed doubt (I might be wrong though) that it could be fuel filter since car would eventually start well just like it did with the previous fuel pump. I have intended to ask him to replace the fuel pump. I do hope you see it this way too. If you think otherwise, I'll appreciate your advice. My question, however, is, is there something that could potentially be ruining fuel pump in cars? I hope I'm explicit enough. Sorry for the long write up. Kind regards.
Jul 13, 2019 at 9:35 AM
Okay, first a clogged furl filter will not stop a car from starting. There is a bypass.
I don't know if it will fix it. It is an expensive guess. I would have your guy test the fuel pressure before condemning it.
Jul 13, 2019 at 9:41 AM
ROBINAFOR
  • 34 POSTS
Yea, but to the question, is there likely anything that can be causing damage to fuel pump? Supposing the fuel pump has gone bad again. Unless it was a coincidence. Because in the last one year I've had fuel pump changed like four times.
Robin.
Jul 13, 2019 at 11:29 AM
What brands of pumps?
Jul 13, 2019 at 11:57 AM
ROBINAFOR
  • 34 POSTS
Not sure. But I know they were of different makes. Anyway, I had the fuel pump checked by two other mechanics. They said that the fuel pump has no fault as the pressure was okay. But I wished I knew what made the car stopped only to start well much later. Please Roy tell me, is it possible that the fuel pump could have failed only to work well much later? Or, do you think something else apart from the fuel pump could have been the culprit? Thanks.
Jul 17, 2019 at 5:21 AM
Yes. The pump can fail at times. It needs to be checked when it happens.
Jul 17, 2019 at 5:31 AM
ROBINAFOR
  • 34 POSTS
Okay, thanks. I'll check immediately something similar happens again. Kind regards.
Jul 17, 2019 at 7:25 AM
You are welcome.
Jul 17, 2019 at 8:48 AM
ROBINAFOR
  • 34 POSTS
Hello Roy
Still on the issue of the pump, I observed two similar scenarios. First the car was on a slanted position (two left tyres were on a raised platform while the other two were on a lower platform). It was on idle. I observed that there was no power as the gas pedal didn't respond well. Then eventually car went off and wouldn't start. But when I brought the car to a plain ground, it started well again and the gas pedal produced enough power. I returned the car to the slanted position just to be sure and the same thing happened. The same thing happened a few days later again. There was enough fuel, in case you may want to know. Would it be wise to still believe it is a fuel pump related issue?
Robin.
Jul 18, 2019 at 11:15 AM
Did you check the fuel pressure in the slant position and the flat position?
Jul 18, 2019 at 1:04 PM
ROBINAFOR
  • 34 POSTS
No, I didn't. It was at home and my mech wasn't available.
Jul 19, 2019 at 12:58 AM
Let me know when you have it checked.
Jul 19, 2019 at 2:22 AM
ROBINAFOR
  • 34 POSTS
I just checked pressure when car is slanted and when in flat position. Pressure is low when slanted but high when on flat. And same like I said before. Car loses power when slanted but revs well when on flat.
Robin.
Jul 19, 2019 at 10:08 AM
Okay, you have an issue inside the tank. Sounds like a baffle is broken and allowing the fuel to run to the front of the tank and uncovering the pick up for the pump.
Jul 19, 2019 at 10:42 AM
ROBINAFOR
  • 34 POSTS
Okay, I wouldn't say I quite got you. But with what you just said, what would be the next step? What should I do now? Thanks.
Robin.
Jul 20, 2019 at 12:29 AM
