That is a good idea. If the injector isn't the issue, then we need to do a compression test on that cylinder. Here are a couple links that you may find helpful:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Here are the directions from Alldata. That attached two pics correlate with the directions.
______________________________
2006 Ford Truck F 150 4WD Pickup V8-5.4L VIN 5
Compression Test
Vehicle Engine, Cooling and Exhaust Engine Testing and Inspection Component Tests and General Diagnostics Components Tests Compression Test
COMPRESSION TEST
AllData Editors Note - Ford does not provide a cranking pressure specification, only an acceptable range.
Compression Test - Compression Gauge Check
1. Make sure the oil in the crankcase is of the correct viscosity and at the correct level and that the battery is correctly charged. Operate the vehicle until the engine is at normal operating temperature. Turn the ignition switch to the OFF position, then remove all the spark plugs.
2. Set the throttle plates in the wide-open position.
3. Install a compression gauge such as the Compression Tester in the No.1 cylinder.
4. Install an auxiliary starter switch in the starting circuit. With the ignition switch in the OFF position, and using the auxiliary starter switch, crank the engine a minimum of 5 compression strokes and record the highest reading. Note the approximate number of compression strokes required to obtain the highest reading.
5. Repeat the test on each cylinder, cranking the engine approximately the same number of compression strokes.
Compression Test - Test Results
The indicated compression pressures are considered within specification if the lowest reading cylinder is at least 75 percent of the highest reading. Refer to the Compression Pressure Limit Chart.
pic 1
pic 2
If one or more cylinders reads low, squirt approximately one tablespoon of engine oil on top of the pistons in the low-reading cylinders. Repeat the compression pressure check on these cylinders.
Compression Test - Interpreting Compression Readings
1. If compression improves considerably, piston rings are faulty.
2. If compression does not improve, valves are sticking or seating incorrectly.
3. If 2 adjacent cylinders indicate low compression pressures and squirting oil on each piston does not increase compression, the head gasket may be leaking between cylinders. Engine oil or coolant in cylinders could result from this condition.
Use the Compression Pressure Limit Chart when checking cylinder compression so that the lowest reading is within 75 percent of the highest reading.
_________________________________________________
Let me know what you find.
Apr 17, 2020 at 9:38 PM
