Hello, can someone help me with the wiring connectors
going to the coil pack? There is a short in the harness close to coils.
I opened up the harness in this area and made the mistake of not taking photos of the wires now what I'm up against is this. Each connector has two wires with a three-prong female end. There are all different colors no two are the same color. So, A cylinder or number 1 has power when using a test light. None of the other cylinders have power. I cut the wires because I had intentions of replacing all the connectors using a kit. Sold for $70.00
Here's the thing there is one brown wire which is hot. If I take one wire from each of the other three connectors 2, 3, 4, and touch them to a bare spot on this brown wire which by the way was already bare except there was glue I scraped off the other connectors become hot, and the car runs. problem in is I feel this not the way these wires should be. But I see no corresponding wires of the same color as the ones coming out on of the connectors. That is further down the harness so I could splice new wires together. The brown wire that's live goes to number 1 cylinder. Do all the other connectors get power from this one wire?
Thanks. JC
Thanks. JC
Dec 26, 2021 at 9:57 AM
