Okay, If you look at pic 1, it shows cylinder location. Pic 2 shows the coil and indicated what cylinder spark plug wire to connect at that point.
Vehicle Power-train Management Ignition System Firing Order Specifications Mechanical (including Torque)
MECHANICAL (INCLUDING TORQUE)
Firing Order .................... 1-2-3-4-5-6
___________________________
If you have the 3.8L V6, see pics 3 and 4. Note that the coil pack should indicate cylinder number. Also note that the layout of cylinders is opposite between the two different engines.
Feb 10, 2020 at 3:53 PM
