Codes P219C and P11EC?
2015 LEXUS NX 200T
118,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
I read something out there but not sure if it's a TSB, related to valve guides maybe but I don't understand what they mean.
Nov 17, 2023 at 3:43 PM
P219C - Bank 1 Air/Fuel Ratio Imbalance: This code suggests that there is an imbalance in the air/fuel mixture in bank 1 of the engine.
So, I would check for vacuum leaks and try servicing the MAF sensor but if cleaning it does not work, I would replace it with a new unit. Use this guide when the engine is cold only:
and
https://www.2carpros.com/articles/mass-air-flow-service
Here is the location of the MAF sensor below.
There is no TSB for valve guides.
P11EC (or similar codes like P11E9, P11EA, P11EB): This code isn't a standard OBD-II code and might be specific to Lexus vehicles. The exact definition can vary, but in many cases, codes in this range are related to issues with the air intake system, turbocharger, or engine sensors. It might also relate to the Variable Valve Timing (VVT) system or other components that affect engine performance and emissions.
Nov 17, 2023 at 6:16 PM
