The codes listed above are present codes.
Things that have been done:
1. MAP sensor cleaned.
2. Dealer reprogrammed the interface module.
3. Both O2 sensors have been replaced.
4. Check engine light is on.
Performing the driving cycle all sensors have check in but the Cat and Evap. I only have 2 drive cycles done so far. The PCM has a permanent code logged for the P015B plus pending codes. all other codes are pending. Check engine light is on. Not sure what to do next.
Thanks
Kevin
Thanks
Kevin
Mar 28, 2023 at 12:15 PM
