Good afternoon.
Did you replace the PCM? This code is about the VIN number not matching the PCM.
P0513
Item Description
Symptom/DTC P0513
Descriptor
Invalid Skim Key
Probable Causes
Ignition Key
Incorrect VIN in Powertrain Control Module (PCM)
Incorrect Vin Programmed in the Powertrain Control Module (PCM)
Invalid Sentry Key Immobilizer Module (SKIM) Key Not Present
No Communication with Sentry Key Immobilizer Module (SKIM)
No Communication with Sentry Key Remote Entry Module (SKREEM)
No VIN Programmed in the PCM
Sentry Key Immobilizer Module (SKIM) Trouble Codes Set
VIN not Programmed
May 25, 2018 at 1:13 PM
