Okay.
The 68 possibilities are below:
P0068
Item Description
Symptom/DTC P0068
Descriptor
Throttle Position (Tp) Sensor Inconsistent With The Maf Sensor
Probable Causes
Air Leak Between Mass Air Flow (MAF) Sensor and Throttle Body
Mass Air Flow (MAF) Sensor Damaged
Throttle Position (TP) Sensor Damaged
Throttle Position (TP) Sensor Not Seated Properly
The 1120 is a reference voltage code. this is the reason the 68 code came up. when this code is repaired, the 68 should go away
P1120
Item Description
Symptom/DTC P1120
Descriptor
Throttle Position (Tp) Sensor Out Of Range Low (Ratch Too Low)
Probable Causes
Reference Voltage from Powertrain Control Module (PCM) Open to Throttle Position Sensor
Reference Voltage from Powertrain Control Module (PCM) Shorted to Signal Return
Throttle Position (TP) Sensor Loose Pins
Throttle Position Circuit Connectors Corroded
Throttle Position Circuit With Frayed Wires
Mar 26, 2018 at 12:03 PM
(Merged)
