This has been an on going problem for month; the ABS and suspension control modules and under hood fuse panel have been replaced. The last thing that was done was additional ground wire was connected at ABS plug connector and all wire connectors at plug were adjusted and cleaned for proper connection. this lasted for 3 weeks. Then the same codes came back: c1232,c1234,c1241,c1242,c1287,c1295,u1000,(anti lock)
C0579,c05854,c0589,c0594,c0691,c0710,cb2795,(suspension control), b2723 transmission,pref. Switch circuit high, u1040,lost communication with brake /traction control system. as you can see this is a major open circuit but it is only drops out intermittently. Codes will not. Clear at all and the traction and ride control and active handling are coding but the 80 mph limit is not on.
Nov 9, 2019 at 8:33 PM
