Just to weigh in on this. These are codes that are typically pulled up from an aftermarket code reader on these higher line products. These codes are not trouble codes but instead just informational.
The E8 means the engine control module was interrogated for codes. The E9 means the Transmission control module was asked for codes as well.
If these are the only codes that you have then there are no issues with the vehicle that would set a code.
Hope this helps. Thanks
Apr 9, 2022 at 9:43 AM
